Configure IGMP Static Members
Configure IGMP static members to add members to a snoop group. You can create a static entry to forward multicast data streams to a particular set of ports within the VLAN. After you create the entry, multicast data streams are always forwarded to the multicast router within the VLAN, in addition to the ports in this static entry.
Configure interface static members:
Switch:1(config-if)#ip igmp static-group 239.1.1.1 239.1.2.1 port 2/1 static
Variable definitions
Use the data in the following table to use the ip igmp static-group command.
Variable |
Value |
{A.B.C.D} {A.B.C.D} |
Indicates the IP address range of the selected multicast group. |
port |
Adds ports to a static group entry |
{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} |
Creates a static group entry. Specifies the port or list of ports that is a member of the VLAN interface being configured to which you want to redirect the multicast stream for this multicast group. Identifies the
slot and port in one of the following formats:
<static|blocked> |
Configures the route to static or blocked. |
